Hi Stick,
Your sketch helps a lot, now realize it is not true sweepforward
or anhedral. The portions that are normal could dilute the rest.
Like one thread says "it looks cool man!"
Bottom line, lesson to all the comments, you only have a first draft so changes for better are possible.
Your serious? Tactical approach would be a hand launch glider until that is fine, from there a simplistic small R/C, that works then
on to the real thing.
You are in virgin territory and the best would have a hard time
assuring success, even NASA uses development series.
Bottom line>> you have to want to do it and be willing to
concentrate.
OK? Good luck !
[email protected]
