RE: Webra 50 Problem
I'm guessing it was just a dry engine you were hearing. Engines retain a very thin coating of oil on the parts after running. You cleaned all that off and were hearing metal to metal contact....cylinder to piston, bearings to race, con-rod to wrist pin and crank. There were lots of places for the noise to come from....probably a little noise came from all of them.
Wiz
