RCU Forums - View Single Post - Jeti DS-24
Thread: Jeti DS-24
Old 06-24-2021 | 08:05 AM
  #1978
ZB
Finally we got: Possibility to deactivate the "inactivity alarm" in the transmitter
Zb/Jeti USA
JETI DC/DS Update Version 5.06 (June 2021)
New Features:
1. Support for R4 RES (device explorer)
2. Support for DC/DS-14 II transmitters
3. Added information about the active throttle channel in the "other model options" menu
4. DC/DS-16 II - increased number of telemetry controls to 16
5. Negative values for "trim-max" are enabled in the function assignment menu
6. Automatic reloading of the telemetry sensor if the user has changed any description of its
parameters (MULi6S Module)
7. Added Czech and German language for “MULi6S Module” sensor
8. Possibility to deactivate the "inactivity alarm" in the transmitter
9. Setting the minimum volume in the transmitter completely mute the sounds (also added
“mute” icon)
Modifications:
1. LUA „io.open“ opens files in binary mode (emulator only)
2. Correct display of pins set as "digital input" (alternative pin configuration)
3. Changed the icon of the third (undefined) state in the “sticks/switches setup” menu
4. Changed the value for turning on/off the throttle switch in the “sticks/switches setup” menu
5. Modification of possible inverse logic of some switches for copied models between
transmitters
6. Modification of the display of the ‘F1’ button icon in the “wireless modes/trainer” menu
7. Modification of the function of the trim buttons during flight mode switching
8. Change of adjustable delay during flight mode switching
9. Modification of the possibility of using standard trim buttons for a new digital trim
10. Delete old system files from SD card (not user files)
