When you build yours I would suggest that you modify the landing gear slightly from what is shown on the plans. If you compare the gap at the top of the main gear to the short video of the test run in post 92 or the photo in post 79, you will see what I'm talking about. I would make the steel tabs shorter and add that to the length of the main gear
