Originally Posted by
Zabriel
A very old thread but I hope I can get help:
I bought a second hand 87" PilotRC Yak54 with a DLA56 on it. The engine (and the plane) looks as in a very good shape. Bu I am frustrated! I can not start the engine without a starter. As soon as I apply a starter (max 6 turns with a starter) the engine runs great. When it stops, I am able to start it while the engine is hot by hand with a few flips. But when the engine gets cooler again, I need a starter to get the engine running. I checked the ignition, changed the spark plug, checked the plug spacing. Everything is as it should be. Also the carburettor. When it runs, its running great. I have the same problem with a DLE35RA, wich I bought new.. After over 70-80 flights its doing the same. Before I started it also by hand in every condition.
Has anyone had ever a similar problem?
Zabriel
Truckracer
If this is primarily a cold start issue, I’d look to see that the choke plate is closing completely.
Zabriel
Checked already. Nothing wrong with them. But a friend told me that the piston rings could be stuck when they are cold. I am going to check them next week.
Truckracer
Does the engine have good compression when cold and after being run. If so, probably not a ring issue. Do you know what kind of oil the prev owner used? What are you using.
Zabriel
Both engines have good compressions. When hot, they turn slightly easier. I don't really believe like its a piston ring issue either.
I am using the same gas from the gas station all club members buy their own. I use a total ratio of 1:30, 80% of its content is synthetic, 20% is mineral.
HOORAY! Problem solved! Words are not enough to tell you how happy I am!!!
I did all the checks adviced above. Finally I discarded all my fuel and bought a new canister, and new synthetic 2stroke oil. Mixed with a ratio of 1:32.
I pulled the plugs out, cleaned them, and as they were new I did not change them.
WITHOUT PRIMING (!) and the throttle slightly above idle, I flip the propeller 7-8 times untill the engine pops. Then I immediately close the choke and at max 3rd or sometimes 4th flip my engine starts! (I did this for over 3 weeks now)
Thank you all for all the replies!
Best Regards
Deniz
