RCU Forums - View Single Post - Ziroli SBD-3 Dauntless build
Thread
07-17-2021, 09:39 AM
94
BatteryBob
After applying a layer of Easycoat to the LE and TE of covers, you have to apply pressure in the center to make sure the Easycoat stays under the tips. I still needed to come back and do a little touch up. The parts need a little push to release from the packing tape.
The fit is real decent.
I labeled each part but they are easily interchangeable given the wing profile is the same across the center section.
Working on the panel lines. I used a couple of different books to find the best layout vs. what I've seen in other builds.
I wanted the entire wing together to make sure the panel lines were aligned from section to section.
The flap hatch is going to be in the path of a panel line.
All the hatches needed a little more work to make them properly recessed into the wing.
Reply
Like
BatteryBob
View Public Profile
Send a private message to BatteryBob
Find More Posts by BatteryBob
View iTrader Profile
