The tillotson is leaking because the pop off pressure is too low. You need to increase the spring tension on the metering needle. I’ve done this mod and the engine ran like poop. The mid range was overly rich and it got worse when inverted. Your best bet is to sort out the Tillotson or get a replacement Tillotson.
