I love it. S-148 servos in the wings for what I assume is the ailerons. Those are actually still available, if they will work with whatever brand of receiver you go with. I'm just wondering if they are still good after this long. I've got a servo that was never used that actually had the cord corrode so, if you still want to use them, you should test them on the ground somehow first. Maybe Speed knows if Futaba servos are compatible with Spectrum receivers, assuming you go that route.
