RE: world models gs spitfire
I searched the web site and could not find the 80 inch version.
I did find an 80 ince Zero
ZERO G.S.
Wing Span : 80.0 in / 2030 mm
Wing Area : 1085 sq in / 70.0 sq dm
Flying Weight : 17 lb / 7700 g
Fuselage Length : 67.7 in / 1700 mm
Engine Required : 2C 1.60 cu in
Radio Required : 6 channels, 9 servos
Key Feature
Top quality wood construction with fiberglass fuselage
Anti-vibration engine mount
Detachable 2-piece main wing
Detachable stabilizer
Spring loaded retractable landing gear
Scale plastic spinner with aluminum backplate
Pre-hinged flaps for smoother landing
Elevator bellcrank to eliminate any differential throw
Fiberglass cowl comes pre-painted with 3-D template
Canopy and pilot come pre-painted (Drop Tank Optional)
