This item is new in the box. This item is PNP (Plug-and-Play). You only need a receiver and batteries.
Key Features
- Easy to complete, bolt-on final assembly
- Exceptionally strong 55 times EPO foam
- High-output, 4250 KV550 PAEP Brand High performance motor installed
- Digital high-speed, 17g digital metal gear servos installed
- Fully-hinged control surfaces with control links installed
- Modern cockpit details and pilot bust installed
- Efficient interior ducting provides generous component cooling
- Small up wing to make the performance better
- Large scale, stable flight platform handles windy condition
- Large, scale control surfaces for aerobatic flight
- Spacious battery compartment gives pilots the option of flying light weight 5S batteries for full 3D or larger 6S batteries for more sport and longer run times
- Strong landing gear
- Pinned rudder hinges
- Upgraded wooden prop
Needed to Complete- 4+ Channel Radio System
- Lipo Battery
- LiPo Charger
What's in the box?- (1) F3A Olympus PNP, 1400mm
- (1) User Manual
