I'm installing a 90FG on the Black Horse Gilmore Red Lion. I have the Keleo ring. In order to fit over the motor box, I need to use the longer stand-off's. The problem is getting the longer bolts into the hole. The fins between the cylinders are over the bolt hole. Is there some trick to getting the longer bolts to fit?
