SJN's easy solution definitely does the job . I like my engines to be removeable without having to access the back of the firewall which usually means fuel tank and other items need to be removed first . For me it is more beneficial to me to use the studs which are installed into encapsulated t-nuts with loctite . To remove the engine the only thing I need to access inside the fuselage is the throttle rod , which has easy access .
