RCU Forums - View Single Post - Question on Futaba 149DP RX...
Old 11-11-2003 | 01:15 PM
Krysta
Default RE: Question on Futaba 149DP RX...
Hi Larry,
No, if you are needing to use all 9 slots for servos, you will need to use a y-harness into any other channel but the DSC and plug in a servo and your battery to the same slot.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
