RCU Forums - View Single Post - ailervators to knife edge mix problem 9cap
Old 11-11-2003 | 01:46 PM
Krysta
Default RE: ailervators to knife edge mix problem 9cap
Hi negy1,
Are you using a Pmix for your Ailevator function, or are you using the Ailevator mix? If you are using a Pmix, for this set up then you will need to link the mixes 6 and 7. If you are trying this only with Ailevator mix and then the 6 and 7 Pmixes and it is still not working for you, I would suggest that you go into a blank model and retry this set up as you may have another mix turned on which is inhibiting this action.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
