You should be able to run you finger over the regulator and it should feel smooth. I.E. Flush
This is a good starting point. And it should run at that setting.
Also when adjusting the high end go one click and wait ten second. YS run with pressure so it will take a few seconds for the change to happen. Also pinch the line for a second the motor should pick up some rpm. If it does not them you are to lean. Do this on the high and low end.
An APC is a good prop for this motor.
What kind of fuel are you using? You need 20% oil. If you do not have at least 20% oil you will burn it up.
If I was you I would try Cool Power 30% Heli fuel. I have been use it for 3 years now and it works very well in all my YS motors.
Mike
