RCU Forums - View Single Post - Flameout Issues!
Old 09-12-2021 | 09:14 PM
Zeeb's Avatar
Zeeb
My Feedback: (41)
You should NOT "assume" things.....
I have one Behotec engine and have not used it much, but the start sequence is different than other Turbines I have. I will note that the KingTech engines require a three cell LiFe battery for the ECU, while maintaining that a "start" sequence must not be initiated with an ECU voltage over 10.0 volts and they are NOT lying.
This prohibition is not due to some issue with the ECU, or the engine electronics, but the starter glow plug will NOT take over 10.0 volts without burning out.
Please be aware that Turbine engine settings, unlike their glow counter parts, ARE NOT APPROXIMATE!
Start over with a fresh setup on a different model memory with the required settings and see how things go......
