JetCat 180RX
JetCat 180 RX
Turbine had all the updates done early on. Had a clean up a new bearings (before required) I think 4 years ago. Since then it's been in 2 different jets and only had 35 starts with 5 hrs 6 mins of trouble free running. So approx 20 hrs before it will need a service (which is over 120 flights.)
Includes:
Turbine, FOD, v10 ECU, Pump (bus), Itairco pump mount, ECU 3D printed mount, IO board, 3D printed IO mount, Jetcat telemetry module, ground data terminal, all cables and good aluminum fuel filter (if you want it.) Comes in the original box with the styrofoam to fit (great for shipping back for service etc.)
