Wow- got a fast response from Rick at Booma. All you need is a Y harness, to tap off the signal wire going from the primary (telemetry) receiver to the airspeed sensor. An install similar to what's shown here will work. 🙂 If you're using dual receivers, your primary receiver should be installed at A1 as shown.
