Originally Posted by
AWorrest
If you are using analog servos, I had the same problem with an AR637T. By default the signal the receiver sends to the servo has a 11ms frame rate. This is too fast for some analog servos. This setting is separate from the frame rate that you set for the transmitter to the receiver. You can set the frame rate for each channel through the forward programming menu. I don’t have my receiver in front of me but as I recall it is at the beginning of the forward programming in the Other submenu.
Allan
That's actually some good info,. I am using digital servos, but unfortunately the AR9350 is not compatible with forward programming, and the older app does not have a menu selection for that.
Thanks tho!
