Originally Posted by
AWorrest
In the DX8e manual it states that a AS3X Gain Live View telemetry screen can be set up on your transmitter where you can adjust the gains. Setting up the screen also establishes a gain menu in the Function List. This apparently only works for receivers without forward programming, such as the AR9350.
Allan
I'll have to try that, tho I'm wondering if that will address my issue. Its not that I have problems setting up the gains, it's that there is very little movement in the surfaces no matter WHAT the gains are set to. You've definable given me something to work with, maybe it will work the same for a dx9.
Thanks!
