RCU Forums - View Single Post - Yellow Aircraft F-15 60th Annirversary Japan RTF
Old 10-09-2021, 01:15 AM
brandom79
Default Yellow Aircraft F-15 60th Annirversary Japan RTF
Japan Air Force 60th Anniversary Scheme
-Pneumatic gears with primary and secondary gear doors
-Jetcat P140rx
-Pneumatic wheel brakes
-Full Scale light system with realistic flashing characteristics and top notch after burner rings (all custom from detailsforscale)
-Electronic low loss brake valve
-Pitot tube
-Jeti r/x (negotiable)
-Working pneumatic barn door air brake
-High end connectors and servos and components
This is a great jet. Possibly one of the easiest to fly and very stable. Asking $5K. Contact me for more info. It's as scale as I could possibly make it and I spare no expense when I build a jet. This was originally a kit version (not the ARF) that was built up to by a professional building service to the ARF kit point, then I finished it up. Its quite a show piece. The blue wingtip stripes are glow in the dark.
brandom79 is offline
