Originally Posted by
YellowAircraft
Hi,
How much ballast did you guys have to add? With what equipment on board?
I did not add any ballast to mine. I run two 5000mah liposuction for the electronics and one 3300mah for the turbine. I have the scale cockpit that helps and use a Swiwin 180n turbine for power. I am also running a kingtech smoke pump with its own uat that is mounted in the front..
Tone
