RCU Forums - View Single Post - KMP Hurricane in detail
Thread
10-18-2021, 04:06 PM
855
limodune
Got the motor battery and ESC install done--- ended up being a shoe horn fit but it's all in and working, also put in a new radio tray and moved the servo's forward and now have all the surfaces working, I replace the single servo for the elevator with two servo's and the rudder servo now works with pull-pull wire, retracts are in and working, also made up a sunken cockpit, I will give it detail later
Done a wt test for the 380 KV motor and 16 x 8 3 blade prop, with an 8s 5000 battery - 73 amp @ 2200 wt
AUW with batteries just over 14 lb, C of G about 105mm 107mm with a little nose down, did not have to add any weight to achieve this
a couple of small jobs to do and it's ready for a maiden
Mike
Reply
Like
limodune
View Public Profile
Send a private message to limodune
Find More Posts by limodune
View iTrader Profile
