Pick Which outboard Motor is best for You!
As all know, there are two types of stroke outboard motors.
When it comes to deciding between a 2 and 4 stroke motor, it comes down to your preferences and the boat you have. You have to determine which features are most significant to you, whether motor weight, parts, fuel efficiency, or many more. As with any purchase, always do research online. CG Marines a 2 stroke or 4 stroke outboard motor manufacturers’ statements and boat tests online can also benefit guide you in your search.
The environment in which you can use your boat is another crucial factor to consider. For instance, when buying car tires, you will not purchase snow tires for driving in Phoenix, where it does not snow. A similar concept applies to your boat’s motor, so decide on how you use it—either for fishing, performance application, or transporting heavy loads.
Finally, picking a product largely depends on who your local supplier is. Sometimes, the decision is not just about the engine itself, but rather your capacity to support the development when it breaks down or requirements annual service. For instance, you will not want to buy a Subaru if there is no Subaru supplier for 100 miles.
