Grab a beer and some crisps, you have some reading to do. Don't try to take it all in in one go.
Take it to the club, let them have a look at it, join the club.
Troubleshooting is much easier to do live, less questions because they can see a lot rightaway.
What plane/make/size/type/mass?
What happens when you connect servo instead of ESC on throttle channel? Does it move with the stick you expect it to, full throw?
What is the battery type/voltage/#cells/capacity?
Charged correctly, what charger?
Same question for controller, there should be some voltage indication.
Propsize and -diameter?
(Small changes, massive effects: current
drawn is proportional to pitch,
voltage², Kv³, and diameter⁴.)
Current and voltage-sag when running, rpm?
Other possible causes and solutions:
Motor stuttering? Won't run?
Vriendelijke groeten
Ron
• Without a
watt-meter you're in the dark ... until something starts to glow •
E-flight calculators •
watt-meters •
diy motor tips&tricks •
Cumulus MFC •
