RCU Forums - View Single Post - Tips for a used R50?
Old 10-24-2021 | 08:41 AM
flydawg's Avatar
flydawg
as far as bearings, the only bearings I've had to replace are the one way bearing. I'd be more interested in the main shaft being straight and the feathering shaft being straight. you can put some spindle oil in the bearings. However if they are sloppy then should be replaced. someone at one time has obviously had some care for that helicopter b/c of the head and the align onboard glow igniter/lipo voltage regulator
Thunder man (10-27-2021)
