RE: updated jet rules
chris zonio posted this on the jet side
Here's some info on the proposals:
One of the proposals is for re-certification of turbine waivers on an annual basis. The recert requires a minimum 18 turbine flights during the previous year to be signed off by a turbine CD.
The other proposals are to change the turbine model weight limit to 55 lbs measured DRY and limit the fuel capacity to 1 and 1/2 gallons per engine.
Buddy box training is also proposed. Finally, a proposal to eliminate T/W ratios and speed limiters is included with an thrust increase to 70 lbs static.
Chris
there are two things at work here, first the rule set itself. but then the manner in which they are being handled.
in the AMA bylaws, Article VIII, section 2
"Special Executive Council meetings may be called by the President, or
by any five Executive Council members, or shall be called upon the
written request of 5% of voting members of the Academy. The purpose of
a Special meeting shall be stated in the call. Except in cases of
emergency, as determined by the President, at least 15 day notice shall be given."
It just seems a little odd how this issue is being handled so quickly.
mongo it was not all jpo members from what I understand. these changes are a response to a request made by the ama apparently.
