RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 11-11-2003 | 08:07 PM
bn120
Default RE: gas fuel with glo plug no ignition
if in facyt it will run on gas then you could control the timing by the heat applied to the plug 1.5 volts would be hotter than 1 volt so it should fire sooner.whatcha thinks? if this does indeed work I will make all my conversions with a 3 volt pack with a petentiometer to adjust the heat(timing)you could always use the glow driver from a power panel you can adjust the heat it and see if it works.
Darin
ps. keep us posted ,this would really be the ticket for alot of people.
