RE: Eagle 2 ARF & 4 Stroke Engine?
Sincraft, I figured it was"female companionship" that was keeping you away. That balsa block wingtip is another place you could use a razor plane (harp,harp). Glad the top wing is done. If you wanted to, you could harden the balsa filler with some thin CA. It will hold up better on that LE. Otherwise you might have powder under your covering if you nick it. Post some pics on your thread if you get a chance.
