Originally Posted by
DaleD
Good day,
Anyone using a FrSky Taranis on OpenTX to fly their multi-cylinder 4stroke engine with the APS PowerFuel pump powered model? I’m hoping to get some help for my UMS 5 75.
I would specifically like to know the programming in the radio used to ensure appropriate fuel flow from idle to full throttle.
DaleD
Hi, have you tried setting up the pump on a spare channel (lets say Ch 6), assign Ch 6 to the throttle and set the pump (throttle) end points at what you think is 5% and 40% (something like -90% for 5% and -20% for 40%) you could also have it assigned to a switch either the ignition kill or a separate switch if you want to turn fuel off whilst engine is running.
Regards Glenn
