RCU Forums - View Single Post - DLA 32cc Problems
Old 11-28-2021 | 04:55 PM
RBean
Default DLA 32cc Problems
Didn't see much about the DLA 32. I got a Top RC Spitfire used with a DLA 32. Flew for about two years with no problems. Then it started running poorly, would not idle, couldn't kill with throttle closed all the way. Thought it was a carb problem. Removed engine and cleaned carb. Didn't see any obvious problems. Engine acted the same. Decided I would just get a new carb. But couldn't find a Tillison carb. Got a carb for a RCGF 32. Same size with an external pulse line. Installed. Same problem. Found the insulator block was cracked where the pulse line nipple went in. I thought I found the problem. Replaced the block. Hard to find DLA parts. Still had the same problems. Its a single cylinder two cycle gas. It is not that complicated. So removed engine again and started disassembling. Found problem, finally. Anyway, part of the cylinder/crank case gasket was blow out. Air was getting through there. Now running great. Upon thinking about it, at one time I found one cylinder bolt not tight. I didn't think much about it, just tightened it down. Probably the cylinder was just loose enough to allow the pressure, vaccume cycle to blow out part of the gasket. Took me awhile to find it. Just though I would share this as it might save others aggravation.
