ORIGINAL: alvin1
ok right,i feel there is no point argueing with you on this,i have made this modification and it does work if that is your problem.your asking me for the page numbers of the modification as described in rays helicopter manual so here they are:they are page numbers 122 and 123 of chapter 20 look at photos 1,2,3,4 this is the modification and the measuring method that i am describing.is it possible that you are mistaking this procedure for somthing else?
Alvin, I dont have nothing agains you. But honestly what you are saying is not logic. MAYBE is work for you bacause as you say one of your rubber dampers stick out from the yoke.
As I toll you on my last post, maybe you has not pushed all the way the rubber damper inside the joke, BELIVE ME, before you introduce the rubber inside the joke put some silicone grease to the rubber so it can SLIP easy full the way in inside.
Then put some grease to the spindle so it can center very easy. This also help the spindle to center himself by the centrifugal force each blade made when the head is turning at hi speed
I dont find the info. Maybe is because I have the old version of the RAY Helicopter Manual. Do thats is on the newer version??? The newer version has a JR 10x program tips on the las pages.
Isaac
