Originally Posted by
Jaketab
Hello - questions please.
Getting set to run in my FG 90R. Locally, Klotz Original Techniplate (100% Synthetic.) is not available.
The Klotz R-50 (100% Synthetic) is available, but I'm not certain this is an acceptable break in oil. Not certain either if a Syn/Caster blend is acceptable for this engine???
Would someone care to recommend an acceptable oil for the Saito so as not to void the warranty???
The recommended oil for the Moki and Valach is the Amsoil Dominator with regard to the blow btechnical data sheety properties - which is what I use in these engines.
Also - Please recommend a good 3 blade prop to keep the motor at 6000 rpm on the ground??? (23x10 or 23x12) ???
The plane, most likely, will be an A6M5 Zero.
Regards - J Tab
If your engine is without mods I suggest to use only what Saito recommends.
If none of this is available in your place I would take only oil with similiar parameters in technical data sheet of original Klotz (see attached)
3 blade Biela semi 23x10 will be perfect combo for Saito + Zero. 6100rpm on the ground and very scale appearance in the air.
