Originally Posted by
darod07
If your engine is without mods I suggest to use only what Saito recommends.
If none of this is available in your place I would take only oil with similiar parameters in technical data sheet of original Klotz (see attached)
3 blade Biela semi 23x10 will be perfect combo for Saito + Zero. 6100rpm on the ground and very scale appearance in the air.
darod07,
Thanks for the info. Just to make certain, does the link below reference the correct Biela Semi 23x10?
Of course, one answer leads to more questions. Regarding the Saito Ignition - I plan on using the Ultra IBEC HV to power the ignition through the receiver. Do you or anyone have experience with using the IBEC on the Saito Ignition???
Thanks - J Tab
BLACP3SS2310 80-90cc Biela 121 : 3b Biela SS Corsair : Aircraft International
