Originally Posted by
Detlef Kunkel
it is also about the absolute pressure in the pulse line. Without a vent hole acting in the direction of the pulse line, pressure or vacuum can build up. One of the butterfly valves then works worse and worse until it no longer opens.
PS from 4 to 3 mm is minus 25%, not minus 40.
Better to have 75% working instead of 100% in a more critical situation.
This evolution of Moki makes absolutely sense in everydays use..
No you are wrong, the pulse pressure never reaches the butterfly valves, it stays in a separate diaphragm chamber
Also the 3 and 4mm 25% is from caliper measurement and the 40% is from pressure gauge measurement, I don't know why they don't correlate, but the sinus function is involved here.. crank movement..
