Originally Posted by
tomhugill
I think if you took one half of the mounts off any gearbox the same thing would happen. There are many happy users of the pdsgb that have never had an issue. However I have found the manufacturer to be very helpful after I managed to bend a final draft shaft which was causing a tight spot. Think he charged me $10 for the repair and that gear pack has been going strong since.
I'm wary of the HL knock offs as they're just as expensive (if not more) and have cut a few corners which I think will effect longevity
That good , I would buy a couple of base units as it’s a good system. Gearbox goes faulty you can replace without tracks and sprockets off. The board manufactures should tweak the setting for realistic wide turns.
