Hello
I maiden my F104 a couple of weeks ago and here is the video. Not much support on this forum regarding the building as it seems, almost every owner is charging the build to others. Plane flew beautifully with just 3 clicks of trim and CG is spot on. Drag chute yet to be tested
https://www.facebook.com/photo/?fbid...27940392758974
Emanuel, in fact Dubro tires are quite soft, but when you charge the suspension and move the plane forward, the camber angle will change and will get better. You can try 6" Robart tires that are a bit tougher
BR
Nuno
