Any Suggestions? Been running in my new FG90 this weekend. I have the prop drive flange timing upgrade and would like to install it. On gear pullers I have been able to find locally the claws that are too large to fit behind the hub. The is only a 1mm gap between the hub and the case. Any suggestions on how to pull the prop drive hub ????? I may try some heat but only as a last resort because it may ruin the magnets.
Thanks - J Tab
