RCU Forums - View Single Post - Pattern only electric powerplant limitations
Old 01-04-2022 | 04:35 AM
orthobird
Default Pattern only electric powerplant limitations
Beginning in January 2022, electric powerplant limitations will allow up to and including 12s packs, 51 volts, for AMA aerobatic pattern competitions.
However, FAI limitations remain at 10s packs, 42.56 volts. FAI competition in the USA is governed by the FAI Sporting Code.This sporting code states:
“Sporting Code 5.1.2.b): Electric powered model aircraft are limited to a maximum of 42.56 volts for the propulsion circuit, measured off load, and prior to flight while the competitor is in the ready box.”
AMA RC Aerobatics Rules state “The AMA Competition Regulations will be applied when the FAI Sporting Code is silent on, or does not provide guidance concerning the conduct or rules of the FAI - F3A events.”. In the case of voltage limitations the Sporting Code has a specific limitation of 42.56 volts.
SO, aside from the FAI, and this questions is for all pattern pilots except the FAI guys
what would be the go to motor and ESC? (if you are considering switching from 10 s to 12 S)
