I had some spare time after errands so the fuselage flying wire pass through rods went in. The holes were made with the brass rod I'm using with an end sharpened. A drill was used to make a clean hole. The wires will pass though the fuselage and have clevises on either end to the wing mounts. This will cut down on hardware used and less weight over attaching to fuselage and wings. Next up I'll move to the tail bracing mounts.
