Wingspan: 2500mm /98.4 in
Overall Length: 1390mm /54.7 in
Flying Weight: Around 3500g
Motor Size: 3541 KV750
Esc With Brake: 40A
Servo: 17gX4pcs
Servo: 9gX2pcs
Radio: 6CH Channel
The design of the ASW-17 is so detailed that FMS engineers made 4 expensive adjustments just to fine-tune the airfoil for more perfect efficiency.
The wings, vertical and horizontal stabilizers are designed with a snap-on structure. Precisely fastens to the fuselage with a single touch, no screws or glue required, and the aircraft is ready in 3 minutes
The ASW-17 is pre-installed with carbon fiber spars, which ensures wing stiffness in high-G maneuvers. The ASW-17 is designed with specialized CNC aluminum spar connectors - allowing the aircraft to maintain the wing geometry in demanding flight conditions.
Performance-wise, a high-quality Hobbywing 40A ESC paired with a Predator 3541-750KV motor 4S kit provides ample power so that the ASW-17 can perform most aerobatic maneuvers.
If you are looking for a glider with stability and aerobatics, look no further than the FMS 2500mm ASW-17!(fmsrcmodel add a .com visit our website)
