If, like most trainers, it has a "Hershey Bar" wing (i.e. each wing panel is a rectangle), setting the balance point at about 25% if the wing chord should be OK. That's likely to be near or on the main spar, so setting it there should work, too. If you can post a picture and tell us the wingspan, we can recommend throws.
