Jeti Sequencer for the gear and MBAR / setting up FAILSAFE
hello there
requesting assistance from the JETI guru
I have a warbird with pneumatic retracts (2 main and one tailwheel)
and, for the doors, I am using an actuator
I am using two of the Jet-tronic double valves to get the gear and tailwheel up and down
I have programmed the sequencer in
and it has worked
But now, I have ordered, and received an MBAR.
I want to set up a failsafe so that if the pressure gets under 400 kPa, the gear will not go up or, if during flight, the pressure drops to under 400, it makes the wheels come down.
I saw the video from Harry Curzon, and his does not include the sequencer. his failsafe is for only gear without doors/sequencer
this is how he says to do it:
go to
advanced properties
then to telemetry controls
in telemetry controls, add a function and call it "gearfailsa"
then change it to "enabled" and see the check mark
then scroll down and keep it at "Switch"
scroll down and set up the condition X > 400.o +/- O.o kPa
leave duration at NIL
and set default from Nil to 100% then hit OK
exit that page and go back to advanced properties
then go to "LOGICAL SWITCHES"
then add a Logical switch L1, create it and label it "GEARFAIL"
then hit edit and
program it such that :
A) Control 1 is "Mx1"
B) Control 2 is "your actual switch you use to activate the gear up and down"
Condition has to be programmed to : "AND"
then hip OK
then with pressure over 400 kPa, you should see a check mark next to control one and with gear UP, you should see a check at control 2
hit exit
then go to model
functions assignment
and where GEAR is, assign the control to "Logical 1"
however, this does not tie in the sequencer
anyone know what I should do
as it stands, it (the failsafe) does not work
thank you
Cam
