I have 5 flights with the bend as in
Original Setup in picture below:
And are now planning on using the
New Setup in the following flights this season
Question;
What to look out for in the next flight? Anything to worry about? Elevator trim perhaps?
Here is where I set zero degrees;
Tail-pipe now pointing so much down, that I will have to bend that fiber-glass nozzle downwards too, otherwise it will be melted.
Original setup and new setup. It will be 10 degrees difference !!!!!
