Originally Posted by
Kristola
It took some time to make all the parts and there is a lot of them. Even making those small axles took several evenings.
Links to operate wheel rotation.
Pretty much done.
I would suggest doing a load analysis on those actuating arms ..
at that physical size I’m not sure if aluminum is up to the task as the preferred material to make them from .
it might turn out you’ll have to switch to a harder metal .
