Forget the ARF, build your own, that way you can control the build quality and you can add one more rib bay at the tips to reduce the wing loading like I did, on the plans it is suggested to add the extra bay if you are flying at high altitude fields like in Denver.
Mine has a 40oz smoke Dubro tank, it is 22 lbs dry, 27 lbs on TO.
