Originally Posted by
Desertlakesflying
I ended up going with a standard horn for the servo that I had laying around and connected the two sides adjusted accordingly and opened the nose gear bay to allow more throw. Works great now. I am also using the Xicoy LG-15 gear controller which allows me to adjust the servo door travel.
Thanks for the reply. Did you insert the ends of both pushrods into the same hole in the horn or did you insert them one behind the other in two different holes?
