Wing day
The wing is the closest to done so I'm putting all focus into it for the day. I cut out the opening to access the wing bolt and installed a rocket motor lug. It worked out pretty good size wise and stout enough to hold form over time. I added balsa wedges on the LE of the wingtips too and bottom for more defined shape once covered. Those are drying now so in an hour or so I'll sand this wing in prep for covering. The goal is to have the wing covered and as much of the trim on as time allows.
