RCU Forums - View Single Post - Royal Ki-61 Build
Old 02-22-2022 | 01:00 PM
  #49
Mtthwacrss's Avatar
Mtthwacrss
Default I know it has been sometime since I last made an update.
Okay I know it has been sometime since I have made an update here. I will try and do better. I have the first retract put in the wing. I need to do a bit of clean up I got a bit carried away with the glue. I also need to get the wheel well built in and the wing skin back on the leading edge of the wing. The kit came with the gear doors that attach to the struts. In need to build the other door and closing mechanism.
I have also put in tubes for my servo wires to pass through the long tube is for the ailerons. I have decided to use one in each wing.
I am getting ready to put the wings together soon per the plans and just want a sanity check that I have got it right 100MM = 3.9370 inches, this seems like a lot of dihedral to me. Granted this is an old kit and a lot of kits had a lot of dihedral back then. Any thoughts on this?
