RCU Forums - View Single Post - CARF-Models Mig 17 build thread
Old 03-26-2022 | 08:57 PM
  #58
Airforce7's Avatar
Airforce7
My Feedback: (31)
Originally Posted by Dave Wilshere
What you have done was the original design idea, on the prototypes the space was a bit limited for the strap, maybe they have found some space with a different layup. Double sided tape is not the idea or solution, but a spacer on the stiff hatch is all that was required to stop the servo lifting. The frame takes most of the load and there is not much load spread over the screws.
CARF’s only failing is not getting the manual out with these early kits to show what was intended. (then we all know that modellers go their own way many times-particularly in Europe)
Thanks for that bit of info Dave. I was given some info to work with for the build by my sales rep just before I picked up the jet. It’s good but the setup for the elevators show the servo mounted to the other side, I guess maybe there was a version with the servo attached directly to the cover? That would be consistent with the J-10 I had. I think what I’ve done will be fine.
